DASYLab
Analog Output Errors with PCI-6251 Driver in DasyLab 10.0
I am having a great deal of issues in trying to set up a DasyLab sheet to generate a varying frequency train for my stimulator.
I have two different TTL generator pulses hooked up to the output and the recorder is showing the exact train I want to send out. However, when I view the ouput on my oscilloscope, nothing will show up.
Currently, I have the output task as a 1 Sample (On Demand) generation mode in MAX. If I change it to continuous samples, I get an error message in DasyLab explaining "the module can display the number of 'values to be written'".
If I change the TTL generator pulse options to a time base set-up "DasyLab" from "driver" I get a saw tooth pattern at a constant rate instead of the square wave pulses that I need.
Please Advise
Message 1 of 14
(7,343 Views)
It is all about timing and time bases.
The 1 sample per setting only updates once per block, typically.
Can you post your worksheet, and also tell me:
 - what operating system
 - what version of NI-DAQmx
 - What version and level of DASYLab? (e.g. DASYLab Full V11)
Thanks... .
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 14
(7,341 Views)
We just upgraded to the DASYlab 11 pro, we were using DASYlab 10 basic, but are still getting the same issues.
Our NI-DAQ is the PCI-6251
We are using Windows XP
I attached the sheet, and if it doesn't work, there's also a screen shot to illustrate our set up
-Ryan
Message 3 of 14
(7,276 Views)
Ryan,
You're already working with Measurement Computing Application engineering... and they're in contact with me.
The fundamental issue is the output task -- the one sample mode is software paced, and not useful for outputting a waveform.
Message 4 of 14
(7,274 Views)
Agreed.
But if I change it to continuous samples I get an error message
Message 5 of 14
(7,271 Views)
"The module can process the number of 'values to be written'"
even if I change it to continuous, have 1k blocks and sample at 10k I still get the same problem
Message 6 of 14
(7,268 Views)
Ryan,
I got some very good results with a MCC USB-1208HS-4AO.
Generating output is always been a problem with DAQ board of many brands.  Since MCC fixed their driver, I had great resuts compered to NI that I always get an error message eventually.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 7 of 14
(7,267 Views)
I set it up in simulation, and was able to drive a simulated output at 51KHz, using your input time base.
This device claims an output rate of MS/sec, so that I would expect 50KHz to be easy. Both the input task and the output task need to be set to Continuous and the same sample rate and samples to read. I used 10k for the samples to read, simply to update the output more frequently.
Message 8 of 14
(7,264 Views)
I changed the input task and the output tasks so that both are continuous, reading at 10k and rate is 50k.
I'm still receiving the same error message
-Ryan
Message 9 of 14
(7,260 Views)
Hi Tom,
Is the MCC USB-1208HS-4AO DAQ board comparable in its functionality to the NI-DAQ PCI-6251? If so, have you been able to send out 100Hz 5V TTL pulses and receiving them via oscilloscope?
Secondly, what is the pricing of that DAQ board
-Ryan
Message 10 of 14
(7,259 Views)
