DASYLab
Average data from two channels into one
Have a snag in my program . What would be the most efficient way to take the incoming analog data from two channels and average it into one channel in Dasylab 13. I tried the the formula interpreter module but couldn't get the result i was looking for with my formula.  IN(0) + IN(1)/2
I also noticed an average module under data reduction but can'f find any examples of it's use.
Can anyone provide an example of doing this reduction ? Thanks Kent.
(6,025 Views)
The formula would be (IN(0) + IN(1))/2
Note the parenthesis ensure that the addition is done before the division.
You can also use the Arithmetic module - all channels (formerly two or more channels) to do an arithmetic mean of all input channels.
The Data Reduction average module does its computation on a single channel. The incoming values are averaged with the previous values. It can be used for data reduction (4 samples in, 1 sample out) or a moving average that smooths the signal.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,020 Views)
Thanks CJ: I missed the second parenthesis .    Smiley Indifferent
(6,009 Views)
