DASYLab
TTL counter
I have a dasylab 13 program that is taking measurements and sending TTL signals through a MC1208FS to a servo motor
that performs a jog forward or backward operation based off the data. The servo motors are 11 steps ahead of the measurment sensors in this application and
I would like install a counter where once the servo is triggered it starts a counter that counts 11 cycles before allowing the next servo adjustment to occure.
In dasylab 13 what options would be the best to perform this task.?
Thanks Kent.
(7,641 Views)
I would use the Counter module with the rising edges as the option and cumulative count mode and per value Output.
Use a combi trigger to sart after thee 11 pulses and make sure to add an action module to reset the counter when 11 is reached so that it would start from 0 again
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(7,638 Views)
Thanks for the response Tom  ,Would you be able to throw together a quick worksheet example of what you mean.I'm finding the counter module
alot different than the usual PLC counters I'm used to.
Thanks Kent
(7,634 Views)
Accepted by topic author KCL64
Here is a litle sample on how to use the combitation
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(7,632 Views)
Thanks Tom for the help.  Your example is spot on,my problem was that I didn't get the threshold set correctly in the combi trigger.
(7,627 Views)
No problem I'm glad I could help
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(7,624 Views)
