DASYLab
Build a trapezoid in DasyLab6 S
Hello everybody,
I have the following issue. I want to build a trapezoid signal with ranges -2 to 2 Volt, 5Hz and slopes of 4 ms.
I even can't find where to build a trapezoid 😞 Help, please.....
Thanks in regard,
PHeine
Message 1 of 10
(10,733 Views)
Does DASYLab S have the Sequence Generator?
If not,  you have to create a Generator with a Triangle Waveform, and then use a Scaling Module with Limits to cut off the top.
I don't have DASYLab 6 anymore, so I can't make you an example that you can run.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 10
(10,729 Views)
I just tried the following...
Generator with Triangle Wave,  5 Hz, Amplitude of 50, connected to a Scaling module, with the scaling set to1x + 0, and the lower limit of -2, upper limit of 2.
Message 3 of 10
(10,727 Views)
Hi there. I think what you are trying to say is I only get a sloped rising edge.
I also want a sloped falling edge.
I have made a drawing and uploaded it into a fotobucket:
<a href="http://www.imagehosting.com/"><img src="" border="0" alt="Image Hosting"></a>
I hope this works. I've never done this.
Thanks anyway for helping me.
Pieter Heine
Message 4 of 10
(10,706 Views)
Did you use a Triangle wave? If you cut off the top, you will have both a sloped rising edge and falling edge.
Message 5 of 10
(10,704 Views)
Accepted by topic author PHeine
Here are some screen shots from my example.
Message 6 of 10
(10,702 Views)
Message 7 of 10
(10,701 Views)
beeps! Still no picture! This is the link: http://imgfreehost.com/out.php?i26929_dasylabsignal.JPG
Message 8 of 10
(10,700 Views)
Please see the PDF attachment above.
Note... you could have attached the JPG to the post... the attach dialog is at the bottom, below Submit Post.
Message 9 of 10
(10,697 Views)
Wow, thanks for the solution guys! It works!
I'll ask somthing later on about a fourier analyse
about this signal.
Again, thanks a lot.
Pieter
Message 10 of 10
(10,696 Views)
