‎03-17-2009 02:13 PM
‎03-17-2009 02:33 PM
In the Write Data module, there is a check box on the left to save the filename to a global string. Please note that this is NOT the same string that you may be using to create the file name.
You have a choice of storing just the name, or the full path and name.
Once you've done that, you can use a text line object to display that global string on the layout. The easiest way to select the string from the properties dialog is to Right click, and choose Global String from the menu.
‎03-18-2009 10:02 AM
‎03-18-2009 10:15 AM
