DASYLab
Command line STOP of Dasylab
I'm trying to find a quick (Smiley Very Happy) way of stopping Dasylab from the command line e.g. from an external script file.
I can STOP Dasylab via a VB Windows based DDE utility (produced by NI/DasyTec), but I need the same degree of control from the command line.
I have several DDE command line utilities, namely TCMD.exe & CMCDDE.exe but none of these work with Dasylab ….even though they control other DDE servers without problem!Smiley Mad
Any ideas??
Paul Towle.
Luk Leamington
(8,548 Views)
Hello all.
This has now been solved .....thanks to Thomas Gebbert at Measx.com.
It only requires a Visual Basic Script file.
Place the following in a file (e.g. named 'Dasylab_STOP.vbs)' & execute from the command line or another script/batch file.
Regards all,
Paul T.
Start
Sub Start
     'Nun alle weiteren Prozeduren/Funktionen hier aufrufen.
     TastenSimulation 'Für DASYLab-Stop.
End Sub
Sub TastenSimulation
Dim WshShell
set WshShell = WScript.CreateObject("WScript.Shell")
'In Überschriftszeile steht immer u.a. ein DASYLab.
WshShell.AppActivate "DASYLab"
' Tastaturanschläge durchführen.
' 'Enter'-Taste = ~; 'STRG+F5'-Taste = ^{F5};
WshShell.SendKeys "~"
WshShell.SendKeys "^{F5}"
End Sub
(8,521 Views)
You can use the datasocket to do this. Launch the datasocket serveur. Read in Dasylab the status of the boolean "samplebool". If he changes, generate an action to stop Dasylab. Now you can use any language supporting ActiveX to set or reset this flag ( VB, Labview ...) and do a very small program (.exe) you can launch as a command line.
See joined a small exemple in labview
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
(8,506 Views)
