DASYLab
problem with Nidaqmx and dasylab 8
I have 2 card synchronised in MAX(rtsi) and as master and slave in dasylab (ni daqmx 7.5 with dasylab 😎 and when i synchronise the configuration in dasylab with MAX, then all configuration of dasylab 'in hardware setup'  of dasylab come as default own clock for the 2 cards. Is it normal ? And how can i solve this problem? thanks for your answer.
(8,038 Views)
Hi ,
i am sure that you can find more informations on the following link. DASYLab is no more supported by NI, only via forum and by retailer.
For french community it is MD Electronic:
regards
Alex
(8,021 Views)
