DASYLab
Configure SCXI-1000DC for use with Dewesoft via 6062e
How can I configure SCXI-1000DC chassis to show more than one module in Dewesoft via 6062e? I can see 16 channels but only from the first module.
The layout in SCXI-1000DC is:
SCXI-1314 into SCXI-1520
SCXI-1300 into SCXI-1100
SCXI-1304 into SCXI-1102
SCXI-1531 (8 x BNC connectors/analogue inputs)
Using NI-DAQ 7.4 to setup chassis. Have tried NI-DAQmx and traditional NI-DAQ, both will only show the first module in Dewesoft.
(7,656 Views)
you have used wrong forum here. Please get in touch with producer from Dewesoft - www.dewetron.com.
MHa
(7,654 Views)
Hello Sir...
I know my  question is not match with this Daylab Forum. But there is no way to find any kind of related question.!!!
I also simillar problems like you..
I'm using also SCXI-1000 strain gage signal conditionor module with PXI module.
My Dewesoft also only can recognize the first PXI Module, that means I can't use SCXI in Dewesoft.
Did you find any solution to apply SCXI-1000 into Dewesoft.??
I hope good news from you.
Thank you.
(6,171 Views)
you have always used wrong forum here. The situation is same - please get in touch with producer from Dewesoft - www.dewetron.com. We can only help you if you use DASYLab instead DEWEsoft.
MHa
(6,167 Views)
