DASYLab
Select cursor channel in layout
Hi
I have a chart recorder displaying 3 channels individually.
Is it possible to select which channel to put the cursors on in the layout window, similar to the small window displayed for the cursor in the worksheet window?
An alternative to this would be to use the diagram display but then I cannot access the cursor values to perform calculations. Or am I wrong?
Any help much appreciated.
Regards
Jocke
(6,011 Views)
For the Chart REcorder in the Layout, you can display the cursor values by selecting this option ... in the layout, while running, I right-clicked over the chart, and selected Survey>>Cursor Text in Layout
Move the cursor by clicking on the channel name in the legend.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,007 Views)
