DASYLab
DASYLab Analog Outputs with different time base / block size
I have MCC USB1608FS with analog input at 10 KHz sample rate, 310 block size, and, need to get that signal onto the analog output (MCC USB3110) with other channels at 50 Hz sample rate, 1 block size.  Anyone have any great ideas?  I have tried 'Signal Adaptation', but it seems temperamental.
Also, just the USB3110 seems to slow everything down quit a bit (50Hz, 1 block size) - even with just a Slider input, single channel...  So maybe I'm doing something wrong with that?
(6,237 Views)
Please contact Measurement Computing directly on this. There are two drivers, the V10 MCC-DAQ driver, and the V11 MCC-DRV driver. They operate a bit differently - the V11 driver handles outputs much better.
http://www.mccdaq.com/support/support_form.aspx
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,229 Views)
Thanks CJ,  I'll try the new driver.
(6,221 Views)
