DASYLab
Saving data into DAT file
I am new to DASYLab. I need help with saving my result into the DAT file. What I want is the control switch to click and then the program starts to save the data. I use the one shot switch with "write variable ranges" in action module. It doesn't work. I've tried to connect the "write data" module with "relay" and connected to write data but the error keeps coming up "The time information or block length of the input channels do not match". What should I do?
Thank you very much,
Jane
(6,542 Views)
The problem is that the controll input of the relays is not the same time base as the signals you store.
You need to syncronize the switch input with the data going through the write module.  If you open the switch and click options, you will find the time base option.
This is probably the best way.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,539 Views)
Dear Tom Rizzo,
Thanks for the help, I got it!
Jane
(6,533 Views)
