DASYLab
Dasy Lab 10 Chart Recorder
I need a little help.  I am running a worksheet on Dasy Lab 10 and am using the chart recorder.  I would either like to make the Ticks stand out more then the Mini Ticks, Or add lines to the chart itself at the major tick marks.  I tried doing this in the Layout area, but as soon as the program started collecting data it brought the recorder to the from and the lines went behind it.  Does anyone know how to make this work.
(6,086 Views)
Unfortunately, there isn't a way to change the line highlighting, and you really don't want to have a bitmap superimposed over the chart, and, as noted, when it's under the chart, the chart will completely draw over it.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,080 Views)
