DASYLab
Save more than 16 channels to a file
Hi, I am using Dasylab Full and would like to save about 25 channels to the same ASCII file, I have been using the write data module, but it has a limit of 16 channels. Is there some way to get all 25 channels to write to the same file, so i dont have to have separate files for a given test?
THANKS!
(6,308 Views)
Accepted by topic author Jeff_EPS
Two images and one worksheet are worth ten thousand words. 😉
EDIT: I missed to say, that the multiplex-modules are manually configured to multiplex data "per value", not "block wise".
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(6,299 Views)
