DASYLab
DasyLab 3.5e on windows 98
I was told that 3.5 would run only on Windows 95. Since 98 is a glorified version of 95, my assumption would be that 3.5 would perform just as well on the newer operating system. Am I correct in my thinking? Please help... thenks...
(7,981 Views)
V3.5 should run under Windows 98. As you say, there's no reason why it should not.
At this point, V3.5 is so old that we do not provide active support for it. If you encounter any problems, we cannot assist you, other than to recommend that you upgrade to the current version.
--cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,981 Views)
