DASYLab
Data filtration with dasylab
Its work ! but i get the same cycle number for two different values (8 and 21 in the picutre for example)
Message 21 of 26
(2,965 Views)
Please define how to characterize a cycle...
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 22 of 26
(2,952 Views)
One cycle is a single sine wave (sinusoid), start at 0 force.
I tried differents way with the combi-trigger, give always the same issue.
Message 23 of 26
(2,947 Views)
Accepted by aboom
So, that is related to the block size. Plus, I'm not sure that you've labeled the List modules correctly. Check that.
The block size determines how often the Write variable is written.
Use a value of about 5 for the block size.
If you want to switch to email.... cj.butler@ni.com
Message 24 of 26
(2,943 Views)
thank you m. CJ for all the answer. iI stopped the read module (i dont understand correctly how its work) and tested directly with the material, its work correctly, my timebase is 20hz and block size 1, maybe its a little fast I will check with block size 5.
the labelation of the list module (module name) has a reverse sense for technical reason 🙂 but thank you for the remark
 I noted you e-address 🙂
Best regards
Message 25 of 26
(2,937 Views)
Accepted by aboom
20 hz and block size 1 is fine, if it works. We suggest a 10:1 ratio, but if it works, keep it that way.
Message 26 of 26
(2,933 Views)
