DASYLab
How I can configure my DEWETRON (DAQP-BRIDGE), I am using PCI3066E board
I need configure my DEWETRON (DAQP-BRIDGE), I am using PCI 6033E. I would like how i can add this hardware to my (divece and interface-from NI menu configuration program)
(10,092 Views)
yy
(10,092 Views)
Hello - there is nothing to configure related to this module. All DAQ series modules have a +/-5V output, so just be sure that the input channel that it is connected to is set to that range, or the scaling will not match.
If you are using LabVIEW, this is easy to implement.
If you are using DASYLab, then you can obtain a DLL from Dewetron that creates a DEWE-MODULES menu in DASYLab, then you can drop an icon onto the worksheet and connect it up. DAQP series modules are controllable via RS232 commands, so you can automate everything. As mentioned, this is built into the Dasylab DLL. This function is also built into Dewetron's DEWESoft turn-key acquisition software.
So it really comes down to which software you will be using for your acquisition.
You can con
tact us for further assistance at support@dewamerica.com
(10,091 Views)
