DASYLab
How do I Pass a signal between 2 Worksheets
I've created a signal evaluation worksheet and I want to pass the signal it is to evaluate from a separate worksheet that generates the signal. If I'm using the frequency generator module to generate the signal how do I output if from the one worksheet and read it as an input on the other worksheet?
(6,415 Views)
Accepted by Williamx
Bill,
You can only run one worksheet at a time.
The way to transfer data from one worksheet to another would be to save the data into a file. DDF is the most flexible for DASYLab to write and for DASYLab to replay.
Use the Files Group, Write Data and Read Data. The file must already exist to configure the Read Data module.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,411 Views)
