DASYLab
How do I create a pop up window in Dasylab 10
I would like to create a popup window with a confirmation button that would appear on my layout so the person running the test has to press the button to continue, Is this possible using version10 and how can I do it?
Thank You
(6,086 Views)
Just figured it out
(6,073 Views)
Did you use the Message module? Or an Action with a request to enter a string or variable?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,065 Views)
