DASYLab
How many channels can I write in a same file with the Write Data Module (Dasylab 12.00.00) ?
I would like to write data from a large number of channel (up to 128) in a same file. Using the write data module, I have up to 16 channels only ! The only solution I found is to save data in 8 different files... Is there any solution to solve this problem ? I use DASYLAB V.12.00.00. Thank you
(6,282 Views)
Accepted by VLM
You can use the multiplexer unit this will allow you to compress 16 channels into 1 allowing to save up to 256 channels into one file.
In the Write File module you can then select options and, under the "Type of input data", select mixed singles values.  You will then need to define how many channels in each input it will receive.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,280 Views)
Thanks a lot.
(6,272 Views)
Please see this knowledge base article describing how to do it.
http://kb.mccdaq.com/KnowledgebaseArticle50372.aspx?Keywords=multiplex
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,270 Views)
