‎02-13-2008 09:45 AM
‎02-14-2008 06:33 PM
The Transfer function / Coherence analysis Module is a DASYLab add-on module. This module will allow you to calculate the transfer and coherence functions for up to 8 pairs of input values. If you have this module it will be located in your Add-on Module folder. Please search the DASYLab Help for details about this module.
Please note that there is a more active DASYLab discussion forum at dasylab.com
‎02-14-2008 06:43 PM
Hi..thanks for the solution......
May i ask that why the forum under DASYLab webpage cannot be open?
I try few days already...still cant open
may i know what the problem going on?
‎02-14-2008 07:25 PM
Hi..actually i need build FRF and coherence by using basicmodule?
Is this possible do in DASYLab if not use the frequency response directly and how?
Thanks!
‎02-15-2008 08:18 AM
‎02-15-2008 08:25 AM
‎02-15-2008 08:27 AM
