DASYLab
How to get several values at one time from a ASCII string which is received via RS232
Hei,
I have a Sensor that gives the follwing reply string: $WI,HT=15,00,+21*3F\r\n
Within this reply string 15 is a setpoint, 00 a current value and +21 the sensor´s internal temperature.
Is there a way to teach DASYLab to get all these values from just one reply string and put them in three diffrent data channels?
Many thanks for you answers.
(Yes, I tried the search first, really 🙂  )
Malte
(9,060 Views)
Configure the module with one data request command in channel 0. Add two channels, so that the module has 3, and clear the Data Request Command field for Channel 1 and 2.
Channel 0 Data Format - search for the start string and then parse the value after it, then skip the comma.
"$WI,HT=" 2a 1x
Channel 1 Data Format, parse the value and skip the comma
2a 1x
Channel 2 Data Format, parse the value and skip to the end
3a \r\n
Let me know if it works. If it doesn't, then post a screen shot of the RS322 monitor window in both ASCII and Hex, so I can see where it's going wrong.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(9,059 Views)
Hei cj,
thanks a lot, it´s working prefectly. ->Thread closed
Some background infos to the sensors (if you´re intrested in): The sensor are ultrasonic wind measure sensor and used by Vestas on wind turbines.
(9,052 Views)
I have a RS232 string which goes something like this:
<STX>,0 123456000000<CR>
I basically want the part which goes 123456, so in DasyLAB's serial input, for data format, I have:
4x a \r
This picks up the 123456, but also the six zeros which I don't want.
I've tried using "bbbbbb" instead of "a", but that doesn't seem to work.
Using "6a" instead of "a" also doesn't work, and DasyLab doesn't like it if I put "4x 6a 6x\r"...Any ideas?
Mark
(8,829 Views)
I'd be tempted to anchor on the beginning of the line with a search string,
For example,
"\x02\x2c" 2x 6a
You won't need to worry about the characters after the 6a, because it will start looking for the <STX>, again, and line up at the beginning.
Hope this helps.
(8,807 Views)
Magic, thanks for your help again!  I found something similar as well and anchored it to the ",0 " sequence.
Mark
(8,805 Views)
