DASYLab
Problems with action modul writing global variables
I want to use the action modul to increase 5 global variables (add the value 1 to the global variable ${VAR_5} ...${VAR_9}). But my Dasylab version 10.0.0.1 adds the value 1 to ${VAR_1} and all other global vars are not increased.
Could anyone help me to solve this problem?
Thank You very much.
Marc
(7,681 Views)
In the Action module parameter field, enter only the NUMBER of the variable, not the placeholder ${Var-xx}.
If you enter the placeholder, the action uses the CONTENT of the variable as the number to increment.
Let me know if that is the problem.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,679 Views)
Hello CJ,
thank You for Your help. Yes, that was the problem.
Best Reguards
Marc
(7,666 Views)
