DASYLab
How to stop and restart a measurement with a specific criteria?
Hey guys,
I'm burning my brains trying to figure out this problematic on my program.
For my research project I am using an O2 sensor that is coupled to a Labjack U12 card and therefore I am getting a constant value of 4 mg/L based on the switch on/off of a AC power plug (connected to the analog output) that is connected to the aeration system. So when I have 3,8 mg/L switches on the aeration and 4,2 switches off.
But I want to run this measurement for a specific time (maybe 10 min) and then stop the signal to the analog output. After sometime the O2 measurement will drop to values of 0 mg/L but I want that when it reaches a specific value (maybe 0,5 mg/L), stays still inactive for a specific period of time (maybe 2 min) and then activates again the signal to the analog output (cycle restart).
Is it possible to stabilish this concept using Dasylab? I would so grateful if you could help me with that!!!
I'm attaching 2 pictures, one from my actual block configuration at Dasylab and the other is the expected measurement after the new configuration.
Hugs and looking forward for suggestions,
Celso
(7,719 Views)
@celsosilva,
I think that the DASYLab addon "Sequence Generator" should be useful for this task. More details under http://www.mccdaq.com/daq-software/dasylab-upgrf2p.htm
MHa
(7,708 Views)
Accepted by celsosilva
Is the curve in the diagram the output of the "Labjack: Ai"-module?
Then you can use the following block-series:
Direct the signal from the Labjack-in-block into a combitrigger-block: Start-event is when the signal drops below 0,5, Stop-event is when the value rises above 0,5 (do NOT use events "is lower than"/"is greater than"!).
Connect the trigger-block to a counter-block, that counts the time the received signal (from the trigger-block) is TTL-high.
Use another trigger-block right after the counter-block: Start-event is when the signal rises above {insert time in seconds}, Stop-event is 'Direct'.
Now connect an action-block, that controls the corresponding aeration-switch (turn on: curve rises, turn off: curve drops -- is this correct?!), the action should fire, if the received signal from the previous block puts out a rising edge.
How to control the 10min-measurement-time with counter-, trigger-, switch-, and action-modules is left as homework. 😉
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(7,688 Views)
the curve in the diagram is not the output of the ""Labjack: Ai"-module".
The output of the Labjack: Ai"-module just gives a signal to the AC power plug that is connected to the aeration system. I am not sure if your configuration is going to work but i will try it tomorrow but many thanks for the help 🙂
Do you know if it is possible to connect the action-block to an TTL-Pulse generator (that is connected to the relay-block) and after the expected 2 min it resets the TTL-Pulse generator (even if the Phase 2 is still not finished)??
(7,678 Views)
It did work!! 😄
I tried the block-series: trigger-, counter- , trigger, -action and worked perfectly!! To solve the 10 min measurement time I used a TTL Pulse generator with 10 min Phase 1 connected to a relay. So when the sensor reaches values of less then 0,5 starts a countdown of 2 min and then the action-block resets the TTL Pulse generator and a 10 min measurement starts again.
Many thanks to the member hw70 😄
(7,649 Views)
Sorry, I can't  write new message, so I write here.
I have a same problem but little diffrent...
I'm trying to get a singnal Lateral accelation using car.(50~90KPH, radious-100m)
Data aqusiton region is 20m
My task is get a specific region of data (9.9~1.1m)
I attemped to using on/off triggring but I couldn't find the answer..(it has not a input condition)
is it possible?
-Dasylab 9.0 : Tool
-Iotech Daq book 100 : DAQ board
-accelerometer : accelation
-VBOX(recelogic) : velocity
seohojin
(7,594 Views)
missed attach..
seohojin
(7,592 Views)
