DASYLab
Is DASYLab compatible with Yokogawa MW100 Data acquicition system?
Im using a Yokogawa MW100 DAQ and are intrested in using DASYLab for more trouble free signal presentation. Is DASYLab compatible with Yokogawa products? I've tried to search for Yokogawa drivers but failed.
(6,416 Views)
I don't know of a driver for it. But, if you have the Modbus option, DASYLab 12 will support that.
From their web site:
A large data acquisition system of up to 360 channels can be assembled using multiple MW100s and standard MODBUS TCP Ethernet communications. When equipped with the /M1 math option, the MW100 can acquire up to 300 channels of external data from additional MW100 units or other devices such as a PLC using MODBUS TCP communications. This provides a total system capacity of 360 channels (60 built-in measure channels + 300 external).
Serial MODBUS RTU communications (RS- 232 or RS-422A/485) can be ordered as a separate option with the same capability.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,415 Views)
Thank's CJ.
But how do I know if I have M1 math functions? Is it a built in function or something in my DAQ software?
(6,406 Views)
I'm not familiar with the device.
I found that information here: http://www.yokogawa.com/ns/daq/mw100/ns-mw100_01.htm
(6,403 Views)
