DASYLab
Iterative Solutions In Dasylab
Hi
I've been struggling with this for a while and I'm all out of ideas, please help.
Is it possible to construct iterative subroutines within Dasylab. I am trying to monitor an air flow rate using an inlet cone. The flow rate is calculate from a measured pressure difference in the cone, temperature and barometric pressure but the solution if done properly requires iterations to coverge on the flow rate. In Labview this is quite easy by using a do while function. Is there a way of achieving same end result in Dasylab? We are running ver 5.63 at the moment but would be willing to upgrade if needed.
Cheers
Richard
(7,682 Views)
Hello, I'm Software developer from DASYLab group and afraid that your application is only usable with a special programmed new modul based on Extension Toolkit for DASYLab. Please check if you can go this not free of charge way.
(7,653 Views)
