DASYLab
Time delay error
I am currently programming in DasyLab using previously collected data.  I continually get an error when using the time delay module that I am not sure what to do about.  The Time Delay module works fine if I use a delay defined in units of blocks, but if I change to delaying the signal by units of samples or seconds, I get an error that reads "The data at one input of the module are of the wrong type."  I have not changed the input, only the delay units (from blocks to samples or seconds).  Why do I get this error?  I have even started over with a blank page, using only my input data and a time delay, to make sure it wasn't anything else on my worksheet that was creating this error.  Please advise.
Thank you.
Message 1 of 1
(8,194 Views)
