DASYLab
how to send a ttl signal with a good exactitude less than 10ms?
i have a pci 6013 (8 input channel) and pci 6711 (4 outpout channel).Then i need to send a ttl signal to a camera ccd to take a photo when a waveform sinus is equal at zero (rising), but when i send this TTl signal with dasylab using generator pulse or combi trigger and readind this signal, i have difference between dasylab pulse(that is exactly) and measurement pulse that is approximate 40ms after.But i need to have less than 10ms is it possible?
Frequence rate =1000hz and block size=512 the waveform sinus is 0.2Hz.i have already try to increase the sampling rate but nothing happens.Thank for your help.
(8,447 Views)
Do you mean the pulse width is 40ms longer than the dasylab pulse?
Jean-Claude J
NI France
(8,416 Views)
Yes, it's possible.
You just have to reduce your block size to 10 !
For more informations, visit Forum Dasylab en français at http://forum.aceboard.net/?login=128657
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
(8,331 Views)
