DASYLab
Modbus Configuration under Dasylab 10
Hello, together using DasyLab 10!
I want from a terminal (network analyzer) data (RS485) with the Modbus.
With a freeware, I can read the addresses, however, does the reading with the Dasylab analog Modbus not!
Have all the same settings (terminal and DasyLab).
The terminal has the following parameters:
ID = 001 baud: 9600 no parity, 8 data stop 1 and no handshake
The following address should read: 28Hex
The data are collected in RTU format:
Under Dasylab analog Modbus I have made this setting without success
Device: 1
Register: 30 or 40 after the field tried all the figures 1-200
Data range 0 - 65535
And I always get the same error message: ComX or command wrong
Hope for your help
Hicki
Message 1 of 1
(8,213 Views)
