DASYLab
Simple Dasylab's program to read a channel of Datashuttle Express parallel port
now with Dasylab 7 i can talk with tha Datashuttle Express,with
editcal i see the Serial number of the device.
So i think that now the serial port comunication is ok.
Now i would like to read a tension value froma a single channel.
Somebody has a little program already done for Dasylab 7 for this?
Thanks in advance.
MAX
(6,993 Views)
Check that DASYLab can talk to the device by opening the Experiment - Hardware settings.
It should display information about the DataShuttle.
If that displays without error, then simply create an analog input module and connect it to a Digital meter module.
click on the Start button (upper left button on the top tool bar).
If this explanation is too technical, then you need to review the tutorial in the Hands On Guide.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,990 Views)
