DASYLab
Omega CN606TC2 with Dasylab 11
s there someone who can help me
I connect CN606TC2 and Dasylab 11... using the RS232 cable, and have done the instruction manual of the book cn606tc2.
In dasylab RS232 module, there is a box:
1). Measurement data request,
2). Measurement data format ...
what should I write in the box is so modules dasylab Digital meters can be read from CN606TC2.
To start communication, the Command Module must send alert code ASCII [L] hex 4C.
Commands requesting data from the scanner:smileysad:CN606TC2)
 ASCII [A] hex 41 = Zones/ Alarms/ Scan time
 ASCII [M] hex 4D = Model/ Password/ ID#/ # of zones
 ASCII [S] hex 53 = Setpoints
 ASCII [T] hex 54 = Temperature
I did not understand the program and the ASCII code.
I send [T] in the RS232 monitor and restore dasylab 54.
I am very grateful for your help
(6,131 Views)
You probably will have better luck getting a solution to this on different forums since these are not NI products. Below are some links that may help you.
Here is the user manual for CN606TC2
http://www.omega.com/Manuals/manualpdf/M2818.pdf
DASYLab
http://www.dasylab.com/
Good luck sorry I could not be more helpful
(6,117 Views)
thank you
(6,112 Views)
Also, consider contacting Omega. They have access to both DASYLab and the hardware, and know how to reach me if they need my help. Without the hardware, I'm not sure if I can assist directly.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,097 Views)
