DASYLab
PID parameters change manually on Layout
Hallo,
How could I change PID/ Kr, Tv, Tn parameters manually from display layout in Dasylab. Anyone can help me?Thanks in advance.
(8,771 Views)
For that you need to use global variables.
To change them in your layout, use sliders that connects to varable reads modules.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(8,770 Views)
here some additonal DASYLab 11.x screen shots for the informations from Tom Rizzo.
MHa
20697i9BA8CA2F1B2D9D31
20699i8E46E2BBB356D88C
20701i098F13240DDB9D95
(8,759 Views)
Thank you!!!
(8,753 Views)
I add variable writer in the following way..
is it right? I did not get result.I don't know, what is the problem with the circuit connection?.....
(8,746 Views)
Do you have synchronized the T1_1_Reg slider module with the output channel 0 from T1_1_Regel? Is there an reason for this handling? Do you have outputs from T1_1_Regel to "clock" the T1_1_Reg? Mostly from you module names sounds be german, is this a way to communicate in german?
MHa
(8,743 Views)
Accepted by topic author 1980
I also don't think you need to syncronize the slider with the output of the PID.  If you need to, you should do it with the input.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(8,740 Views)
