DASYLab
automatic temperature measurement test
I have to read some values at constant temperature for a while. Then, after a certain time the temperature should rise or fall to defined temperature for further measurements. I'm doing it manualley right now,which takes me a lot of time. I want to switch it to automatic mode. I would be very grateful, if someone can help me to some hints to build this block.Thank YOu.
JAMIL
Message 1 of 8
(8,540 Views)
We need more information about your DAQ device, and how you propose to control the temperature.
This is a typical application for PID control, where the target temperature is the Setpoint for the PID.
What version of DASYLab do you have, what operating system, and what DAQ device?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 8
(8,539 Views)
this sounds for an optional usage from
DASYLab Two-Point Control standard module to regulate the temperature under range of tolerance or one of the other 3 variants
DASYLab Sequence Generator addon module to define the temperature program
MHa
National Instruments Engineering GmbH & Co. KG |
Pascalstraße 18 | D-52076 Aachen
Message 3 of 8
(8,529 Views)
Hi MHa,
at first I would like to add that I am not so much used to with DasyLab. That program is done by another engineer. I have to update some features only. If you do not mind could you give some examples of the above module what you discussed. Thanks in advance.
Message 4 of 8
(8,525 Views)
with the Sequence Generator you can write your temperature "program".
20821i93BFAEC6A36CCA3D
This program are the "S=set points" inputs for two-point module. The AI module generate "0" the actual values from your temperature system for two-point module. And the "0" output channel produce the new set values for your temperature system which is to regulate.
20823iE92282ED66151211
MHa
National Instruments Engineering GmbH & Co. KG | Pascalstraße 18 | D-52076 Aachen
Message 5 of 8
(8,518 Views)
Dear MHa,
Thank you for your cooperation. I am using at my Lab DasyLab 7.0 (German Version) . Where Sequence generator Module (Sollwertgenerator Module) is optional. How could I add this module. Actually I would like to make the programm in the following way in DasyLab 7.0.
1st Step: Temperature  100 °C will be constant for 30 minutes
2nd Step:  150°C will be constant for 30 minutes
3rd Step:   200°C will be constant for 30 minutes
4th step:   150°C will be constant for 30 minutes
6th Step: 100°C will be constant for 30 minutes.
I hope your information will help me to build this programm. Thanks in advance.
Sincerely Yours,
Message 6 of 8
(8,494 Views)
the DASYLab 7.0.5 Release is from 2003 and is not longer supported from us. Is there a way that you can update over your local DASYLab reseller to version 11.0.1?
Perhaps is this link useful -> http://www.mccdaq.com/daq-software/dasylab-upgrf2p.htm (included Sequence Generator)
MHa
Message 7 of 8
(8,491 Views)
I concur with MHa... updating your software to the current version will ensure that you have our full support.
There is another way to accomplish a simple set of steps - up to 16 - using the V7 Time Slice module (Data Reduction Group), in V11, this module is called the Signal Switch module. You can configure it to change from input to input according to time.
I no longer have V7, so I won't post an example, but, here is a screen shot of the program in V11. I used Global Variables to store the target values, but you can use a Generator (generate constant), to do the same thing.
20961i58993909971623B6
Message 8 of 8
(8,483 Views)
