DASYLab
Pressure curve sampling
The signal from the pressure sensor is quite noisy before and after the maximum peak that I am interested in, is the any way to just sample from the absolute maximum peak and ignore all other noise?
Message 11 of 12
(3,104 Views)
You can post a sample of your data. Use a Write Data module configured for DASYLab (DDF) format, and post it and the worksheet that you're using. Zip them together.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 12 of 12
(3,101 Views)
