DASYLab
Problems with "set output to "'
 I'm using Dasylab 9.02 in combination with the USB 6009 of Analog Devices. When I use an analog output block and check the option "set output to ... " ( At the stop of the masurement) I get the message " The Ni-DAQmx task saved with the module is not available"  We use Labview to operate a test rig, so we need this function, otherwise the testrig keeps on running when the test is stopped !
What could be the problem ???
(8,539 Views)
Hi Bas,
Did you test the DAQmx outputchannel in MAX? Does it work?
For Dasylab questions, you can contact MeasX.
Bas
(8,515 Views)
 Thanks, Bas,
Yesterday I finally got a solution fot my problem, after almost a year of communication with Dasylab.
As it turns out right now, fot each output channel a separate task has to be defined.  (I used tto have 2 output channels in 1 task)T his is nowhere mentioned in the books or help file !!!
Anyway, finally the problem was soved.
(8,513 Views)
sorry but DASYLab 9.x NI-DAQmx Online help clearly say:
"... Set Output to ... at Stop of Experiment
When the measurement stops, you can set the outputs of the module to a specified value. Enter a value or the name of a global variable.
Click Task for job to select a NI-DAQmx task of the Measurement & Automation Explorer (MAX) that DASYLab uses for the output.
  Note  DASYLab only supports the NI-DAQmx tasks that use the signal generation mode 1 Sample and the corresponding physical channel.
MHa
(8,491 Views)
That seems not very clear to me !
There is written "outputs" , and the Note is not very clear either. :
More clear would be:
Attention: an output task can have only one output !
(8,474 Views)
thanks for the hints to improve the manual description. We would like implement this for next release from driver.
MHa
(8,467 Views)
