DASYLab
wave file dasylab
Hi all,
I'm wondering if there's any way to export signals from Dasylab in the .wav format so that it can be playedback say from windows media player? Your help is be greatly appreciated.
anne
(8,302 Views)
I think you question can be better answer here: Dasy Lab support. Since Dasy Lab is not a programming language, just a graphical interface for data acquisition, you are probably relaying on a third party solution or a plug in for Dasy Lab.
As a suggestion, you probably have your signal on some sort of array which can be exported to a WAV file with LabVIEW.  You can take a look at this link: How to save a sound in wav. Format
I hope it helps
Jaime Hoffiz
Product Expert
(8,297 Views)
More specifically -- no -- DASYLab does not have support for WAV files, either as input or output, other than the ability to play them as part of the Message module.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,290 Views)
Alright. Thanks Jamie, cj!
cheers
(8,284 Views)
