DASYLab
Rename layouts
I'd like to rename and renumber layouts in Dasylab and have not found a way as yet. Any tips? JLW
(7,490 Views)
Rename a layout by going to the page properties (Options menu, Layout Page properties). I usually just double click on the background.
Renumbering is not so easy. You have to remove (delete), and then recreate them in the order that you want. I would consider using the Edit menu to save the layout to a file, then delete it. The others should move up in the list. Then use the Edit menu to Load the Layout back. It should be added to the bottom of the list.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,483 Views)
