DASYLab
Logging CAN messages with DayLab 8.0 using an Ixxat interface
Hello.
I am trying to connect my IXXAT USB-to-CAN adapter to DasyLab and I am getting nowhere.
Is it at all possible to log CAN data into DayLab 8.0 or do I have to upgrade?
A have installed the software from IXXAT and I have downloaded a .driver from dasylab.com consisting of a .dll file. Where shall I put it?
I copied it into my dasylab directory and also into windows\system32.
I was expecting to get at least one new row in dasylab's /modules/inputs-outputs but nothing happens.
Am I doing something wrong or do I just have the wrong DasyLab version?
BR,
T Karlsson
(7,615 Views)
We're sorry for the confusion. The installation notes in the downloaded DASYLab driver do not mention a very important step.
You must modify the DASYLAB.INI file, located in the same folder as the DASYLab.EXE program file, usually, C:\Program Files\DASYLab 8.0 on English Windows systems.
This file has many sections. Edit it with a text editor, such as NOTEPAD. Find the section that starts with [EXTEND]
Depending on the choices you made when installing the software, the section may look like this:
[Extend]
DLL1=TEAC_SLM.DLL
DLL2=TEAC_SPM.DLL
DLL3=DLAB_UX3.DLL
DLL4=DLAB_UX4.DLL
DLL5=DLAB_UX5.DLL
DLL6=DLAB_UX6.DLL
DLL7=DLAB_UX7.DLL
DLL8=DLAB_UX8.DLL
The lines that have DLAB_UX?.DLL are placeholder lines. Replace one of those lines with the name of the driver that you downloaded. For example, I would do this:
[Extend]
DLL1=TEAC_SLM.DLL
DLL2=TEAC_SPM.DLL
DLL3=DLIXCAN.DLL
DLL4=DLAB_UX4.DLL
DLL5=DLAB_UX5.DLL
DLL6=DLAB_UX6.DLL
DLL7=DLAB_UX7.DLL
DLL8=DLAB_UX8.DLL
I replaced the DLL3 section with the correct name of the downloaded file.
When you save this file, and restart the DASYLab software, you should see a new menu item. If the underlying IXXAT drivers are not loaded correctly, you will get an appropriate error message as the software is loaded.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,610 Views)
