DASYLab
Specified board does not have chan/gain queue
I run a Mesurement Computing PC-Card DAS16 /12-ao with version 10.1Dasylab. It started to give an error message on a new worksheet, "Specified board does not have Chan/gain queue."  Is this a timing block size issue.
Wolfg.
(6,538 Views)
Accepted by topic author wolfg
This is specific to the MCC-DAQ driver in V10, and will not happen with the new MCC-DRV driver that shipped with V11.
You need to go to the hardware settings for the MCC-DAQ board, and unselect the cbALoadQueue
From the Help for the MCC-DAQ Hardware Setup:
Tab Functions of the Analog Input
If you do not select a function, the driver uses a 12 bit resolution for data acquisition.
  • cbALoadQueue — Loads the A/D boards channel/gain queue. This function only works with A/D acquisition boards that have such a hardware. If you use the virtual demonstration board, you cannot select this setting.
  • 12, 14, or 16 specify the resolution of the A/D acquisition. If you specify the resolution of the acquisition board incorrectly, the driver measures with the standard 12 bit resolution. If you use the virtual demonstration board, you must select 16 bit.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,537 Views)
Thank you cj
You are fabulous.
wolfg.
(6,531 Views)
