DASYLab
can't seem to obtain data in a specific measurment window
Kent,
Give us a call and we can discuss that
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 11 of 13
(2,872 Views)
Thank you all for the help. I was able to get the worksheet up and running at the required speed.
I ended up using 5000Hz with 100 sample/block .
Have one more question.
Being the digital sub system is slow on this device,what would be the best way to get a signal out to a relay
in real time without having speed issues.  Is there a way of using the analog system to perform this operation?
Thanks Kent.
Message 12 of 13
(2,852 Views)
You could try it. Simply output 5V to the Analog Output. That was Jeff's suggestion.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 13 of 13
(2,847 Views)
