DASYLab
drivers pour DAS 801
Bonjour,
J'utilise une carte CIO-DAS 801 sous Labview 5.1.
Je ne dispose pas des drivers gérant cette carte.
Pourrait-on me venir en aide?
En vous remerciant à l'avance
C. Condette
Enseignant
(8,176 Views)
Bonjour,
La carte CIO-DAS801est un matériel ComputerBoards et non pas National Instruments.
Vous obtiendrez le driver de ce matériel auprès de ce fabricant afin de pouvoir l'utiliser avec LabVIEW.
Cordialement,
Manuel R
AE dans une autre vie
(8,150 Views)
Is this a request for DASYLab or for LabVIEW drivers for the CIO-DAS801 board?
The LabView drivers are available from your hardware vendor, not from NI. Contact your distributor for more information.
The DASYLab drivers are included with the DASYLab installers.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(8,148 Views)
Hi Cj,
Thanks for your response. This is not a request for DASYLab but for LabVIEW.
As the response given in another section to the same subject, the instrument drivers are available from our website, if not you need to contact the hardware vendor.
ManuelR
Manuel R
(8,133 Views)
