DASYLab
gpib communication without Ascii commands
Is there anyway to send hexidecimal commands to equipment on the Dasy lab national instruments GPIB module ie ibwrt (user, 'hex') or does this always have to be a string. Am i using the correct ib command or should i be using ibcmd (user,'hex')
(7,541 Views)
I have found that you can write every Hex number apart from 00 using \x does any one know of a way to send 0 on the national instrument Dasylab GPIB driver.
ibwrt (user,'\x00') doesnt work but for example ibwrt (user'\xff') does work.
(7,522 Views)
You probably have figured this out yourself but does this link help at all?
http://digital.ni.com/public.nsf/websearch/95689440C34E02D186256D89004A5648?OpenDocument
Sarah
Applications Engineer | National Instruments | UK & Ireland
(7,437 Views)
