DASYLab
how do i know, the dasylab version?
good moorning people!
I am not very good at english, because i am from Brazil. I am technician of an enterprise's IT department. I have installed dasylab in a notbook with win xp, we have a license, but a find out a problem i expect someone could help me as fast as its possible. the problem is...
The Dasy lab menu's bar is incomplete it doesn't appear module, options, tools, view, edit. It only appear file, measuerment, window and help.
How can i do for the menu appears complete with all resources.
How can i do to know my dasylab version? Iits only written dasylab 2011 vesion 11.00.00 i don't know if it's lite, pro, basic, full.
thank you
Message 1 of 12
(6,779 Views)
Are you at MSA?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 12
(6,778 Views)
In any case, go to the menu->About and click on the options TAB.  There you will find the options purchased
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 3 of 12
(6,776 Views)
what would be MSA?
Message 4 of 12
(6,774 Views)
How can i do to see the all the menu with the other resources?
Message 5 of 12
(6,773 Views)
Sorry for the confusion,
it does sound like you have a bad installation.  If you contact your local reseller with the SN, you should be able to receive the proper information.
WHat happened when you installed the CD?  which option doid you get after you entered the SN?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 6 of 12
(6,770 Views)
I did a typical installation with the more common features used. after this select my equipment drivers iotech e national instruments.
Message 7 of 12
(6,768 Views)
its a dasylab runtime...
Message 8 of 12
(6,765 Views)
If it is a runtime version, then what you see is correct.
The only thing the user will be capable on doing is running a previously created file with a higher version of DASYLab
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 9 of 12
(6,762 Views)
congratulations you help so much.
Message 10 of 12
(6,760 Views)
