DASYLab
how to put a user text into global string
I use the odbc-interface to save measurement result into an excel sheet.
Now I need the possibilty to enter an additional text into a separate  column.
This text is a free user input string.
But I did not find a way to transfer a string from the message input module to a global string.
Is there a way to achieve this ?
Regards
Andreas
(7,702 Views)
i think that you've got to put it in the string, and display that string in the Message module.
Use the Action module to prompt for the string (String enter or Enter String), and, then the Event "global string changed" can be used to display the message using that string.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,671 Views)
I fear I did not understand the solution.
The only way to input text is the "message input module".
When I enter a text, I can display this user-string in the message module,
but the event "global string changed" within  the action module does not function, because no global string is used.
That's the point. I found no solution to transfer a user-string into a global string.
Do you have a short example ?
Regards
Andreas
(7,666 Views)
What I am suggesting is that you switch the order... force the user to enter the string and then use that string in the message.
See if this example helps.
(7,663 Views)
Accepted by Andreas Graff
That's the solution.
Thank you very much.
( An example says more than thousand words )
Regards
Andreas
(7,651 Views)
