DASYLab
ni task import
Hallo!
I have another question: When I am using Dasylab with my USB 6009 measuring device, I have to use tasks I have defined before in the MAX. When I am now transferring my worksheet to another computer, I have normaly no tasks or not exact the same tasks, and therefor I have to update these tasks.
Is there a possibility to import the tasks from the worksheet to my MAX?
This is especially necessary when I am transferring my worksheet to my measuring systerm with the runtime version of dasylab installed.
Any information for me?
Thanks and have a nice day
Hilby
(6,634 Views)
Accepted by topic author Hilby
No, you cannot configure the MAX with settings from a worksheet.
Start MAX. Export the tasks using the option in the "File/Datei" menu. You'll get a "NCE" file.
Copy that file to your teststand pc and doubleclick the nce-file, to import the saved configuration from the other pc's MAX.
Start DASYLab, start experiment, works.
nce = NI Configuration Export (file)
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
(6,623 Views)
