DASYLab
recorder with variable unit
Hallo!
I tried to use the recorder with variable units. That does not work does it? Can I change the Units of the recorder from the runtime version in any way?
Thanks for your advice.
Hilby
(6,941 Views)
Accepted by topic author Hilby
Hello again!
I have found the solution:
Even when it is not possible to use a variable in the context menu, it is possible to put a global string in the recorder manually. I put "${Unit_Ch1}" into the field for the unit, and it worked.
Have a nice day everybody.
(6,935 Views)
Thanks. I did report the deficiency.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,930 Views)
