DASYLab
output data
I am using a temperature monitoring device using the DASYLAb software. An experiment was run using the software set at default settings and I believe the data collected was not appended and the sampling rate was too high so the resulting data file is very large. In trying to visualize the data, I am getting a response that the file is too large and can only view one block at a time. I would like to know how I can see all of my data on the same chart. Also, I would like to know if there is any way for me to export the data (the files are saved under the ASCII format). Either view the data in a raw format or export the numbers to excel for me to plot the data using that program.
thanks
(7,254 Views)
k-ganeshan,
I am not as  familiar with DASYLab as I am with the National Instruments hardware that can be used with it, and this sounds like a software question to me. I would suggest going to DaisyLabs web support. If another person does not answer this post, I would  recommend contacting them.
-Marshall R
(7,243 Views)
