DASYLab
rs232
I'm trying to send a global string to the RS232 output module. I only want to send one character at a time so I have the 0 channel of the rs232 module formated as [a]. I have the action module set to Send Global String to the 0 channel of the rs232 module and have the parameter value of the action module set to the Global string number I want to send.
But it does not work?
(7,043 Views)
Did you specify the Channel Number in the Action module?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,022 Views)
I got it to work. It was a timing issue.
But thanks for your response.
(7,020 Views)
