DASYLab
Dasylab sends only one string using RS232
I can send only one String when the program has started.
After that the port remains open, but Dasylab does not send the following string.
I used a comportmonitor to see what happens. Dasylab closes and then reopens the port to send the first string.
The serial output in Dasylab is configured as follows:
- No control input
- Single command
- Output format: [a]\r
What could be the reason ?
Regards
Andreas
Message 1 of 14
(9,585 Views)
Did you use an action list to trigger the send command?
Tom
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 14
(9,584 Views)
As Tom has surmised, you have configured the RS232 Output module to send a string or variable using an Action module.
How do you have the Action module configured?
You can zip your worksheet and post it, and let us look at it.
RS232 devices are extremely varied. If you have information about the device, including a manual, it would be helpful.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 3 of 14
(9,555 Views)
Yes the RS232-output is triggered by an action module.
Within the action-module I use "Send a global String". There are no more parameters to configure.
In the meantime I figured out, how to get this program to work.
I had to set an additional switch in "options" of the rs-master-module. (See attached jpeg)
At my comportmonitor I can see that serial interface is periodically closed and opened.
But this seems to be only a workaround.
Each string I send is always 'the first string', because the comport was opened before.
Why can't I leave the port open ?
Regards
Andreas
Message 4 of 14
(9,550 Views)
Andreas.. you didn't mention that you also have an RS232 Input.
There is sometimes a problem between RS232 Output and Input if the device responds to the output and the input doesn't account for it.
The RS232 Output command can include an additional parameter \#n, where n is the number of characters to ignore.
For example, if my device responds
OK<CR<LF> to the command, I would have a string that looks like this:
[a]\r\#4
So that the OK is ignored and completely accounted for before the RS232 Input module does the next measurement request command.
To help more, it would be useful to know the device and the commands, and how often you are doing an input or an output.
Message 5 of 14
(9,546 Views)
The device is a pcb we want to test in our production line. Therefore I send ascii-strings to the device.
The device answers always with a string of a constant length which has the following format:
>xxxxx;xxxxx;xxxxx;xxxxx;xxxxx;CR
The first character '>' is used as start-character to recognize the beginning of the string.
The'xxxx' are five substrings which holds the received parameters and are saved in separate global strings.
So the Output-command is: [a]\r
In the Receive-module I use 6 channels:
1. ">" 5a $01
2. 1x 5a $02
3. 1x 5a $03
4. 1x 5a $04
5. 1x 5a $05
6. 1x 5a $06
This works..... but only one time.
( It would be no problem to send the whole dasylab-program, but it is very complex.
I tried to structure it, but there are only limited possibilities in Dasylab to comment a program)
Message 6 of 14
(9,540 Views)
The received string has ouf course six values not five.
>xxxxx;xxxxx;xxxxx;xxxxx;xxxxx;xxxxxCR
Sorry.
Message 7 of 14
(9,535 Views)
How do you control the Action? Do you have a TTL Pulse Generator?
Usually, when you have a straightforward Data Request command, you use only the RS232 Input configured to send the request, and then process the response, as you have done. Is there a reason that you are using both an Input and an Output module?
You configure the RS232 Input to have a Data Request command in the Options dialog... the Datenanforderung notwendig setting would be set to Ja.
That opens a new setting on the main dialog box where you can enter the command.
My initial thought was that you need to use one of the Handshake settings... there are three that start with "Without" that configure the port to hold the Receive / Transmit control pins high or low. if you try each one in turn, to see if one works?
Message 8 of 14
(9,532 Views)
All action-modules are triggered by a global variable, which is used as an index
to make sure that the actions are triggered in the right order.
This index is incremented by the program and sometimes by pressing a program button.
It seems that I didn't understand the function of the RS232 module properly.
Yes, I use the output-module is for sending strings and the master-module to receive strings.
I didn't know, that I can use the master-module also for sending commands.
I will try this method.
Regards
Andreas
Message 9 of 14
(9,528 Views)
I tested the method using only the input moule.
The input module only accepts constant strings as data request. It is not possible to use a global string ( [a]\r ) .
This is only available within the output module.
In my case I have different request commands depending on the function of the external device.
So I would need separate slave input modules for each command.
How many slave modules are possible ?
I have about 20 commands.
Message 10 of 14
(9,517 Views)
