DASYLab
tradicional NI-DAQ and DasyLab12
  I'm working improving an applicaction for a customer that is using Dasylab 10 with  Traditional NI-DAQ (Legacy) 7.4.4 - Windows XP/2000. Now they have license to use Dasylab 12 (all in win XP). Can you know if Dasylab12 could use Traditional NI-DAQ (Legacy) 7.4.4 - Windows XP/2000 or is decprecated to use with it?
Thanks in advance.
(6,358 Views)
DASYLap 12 uses DAQMx to comunicate with NI products by creating a task and reading it in DASYLab.
Could you use that?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,356 Views)
It's not possible to use it, because I use a old PCMIA Card and the  driver is not in DAQMx.
(6,351 Views)
You know...... my real suggestion would be to purchase a compatible USB or NET card so that you have a guaranty to work 100%.
The cost would not be to bad.
I had the same situation with a customer and we replace it with antother NI card that came with a compatible connector to the final interface.
The changes in DASYLab are going to be minimal
Tom Rizzo
InSyS Corp.
www.insyscorp.com
(6,344 Views)
