08-19-2013
09:41 AM
- last edited on
12-16-2024
04:40 PM
by
Content Cleaner
I'm working improving an applicaction for a customer that is using Dasylab 10 with Traditional NI-DAQ (Legacy) 7.4.4 - Windows XP/2000. Now they have license to use Dasylab 12 (all in win XP). Can you know if Dasylab12 could use Traditional NI-DAQ (Legacy) 7.4.4 - Windows XP/2000 or is decprecated to use with it?
Thanks in advance.
08-19-2013 09:52 AM
DASYLap 12 uses DAQMx to comunicate with NI products by creating a task and reading it in DASYLab.
Could you use that?
08-19-2013 10:51 AM
It's not possible to use it, because I use a old PCMIA Card and the driver is not in DAQMx.
08-19-2013 01:48 PM
You know...... my real suggestion would be to purchase a compatible USB or NET card so that you have a guaranty to work 100%.
The cost would not be to bad.
I had the same situation with a customer and we replace it with antother NI card that came with a compatible connector to the final interface.
The changes in DASYLab are going to be minimal
